I created this irule in order to set rate limit based on source IP:
when RULE_INIT {
set static::maxRate 4
set static::windowSecs 10
log local0. "Var Creation"
log local0. [IP::client_addr]
#check IP
if { [IP::addr [IP::client_addr] equals 192.168.19.12]} {
# set variables
set clientip_var [IP::client_addr]
set get_count [table key -count -subtable $clientip_var]
log local0. "$get_count before increase"
# main condition
if { $get_count < $static::maxRate } {
incr get_count 1
log local0. "$get_count after increase"
table set -subtable $clientip_var $get_count $clientip_var indefinite $static::windowSecs
log local0. "404!?"
HTTP::respond 404 content { "HTML PAGE" } -reset
return
return
This irule create an Array and count session number, when the sessions reach maxRate value the irule reset newest session, until flush.
I realized that when I send a request from the client (with the correct ip) to vs the irule is triggered twice, this means that the array reaches the limit with 2 requests instead of 4.
have you ever had such a problem?
log:
first request:
Apr 30 10:06:24 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 192.168.19.12
Apr 30 10:06:24 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 0 before increase
Apr 30 10:06:24 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 1 after increase
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 192.168.19.12
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 1 before increase
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 2 after increase
second request:
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 2 before increase
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 3 after increase
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 3 before increase
Apr 30 10:06:25 F5SecLab info tmm[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 4 after increase
third and fourth request:
Apr 30 10:06:27 F5SecLab info tmm1[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 192.168.19.12
Apr 30 10:06:27 F5SecLab info tmm1[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 4 after increase
Apr 30 10:06:27 F5SecLab info tmm1[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 404!?
Apr 30 10:06:27 F5SecLab info tmm1[11625]: Rule /Common/Rate_Limit_Irule <HTTP_REQUEST>: 4 before increase
Best regards at all
