Irule Transparent Ridiredt
I have a user type http://elmdemo.access.com and need it to redirect to http://elmdemo1.access.com :6000/elmdemo/sighno.html. I have the redirct working, but it changes the users URL in the browser. I need to redirect them to the long URL with out the URL in there browser changing from http://elmdemo.access.com.
Mike
is it something like this?
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.252:80
   ip protocol 6
   rules myrule
   profiles {
      http {}
      tcp {}
[root@ve10:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:6000 {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
  HTTP::header replace Host "elmdemo1.access.com"
  if { [HTTP::uri] eq "/" } {
    HTTP::uri "/elmdemo/sighno.html"
 test
[root@ve10:Active] config  ssldump -Aed -nni 0.0 port 80 or port 6000
New TCP connection 1: 172.28.19.251(43427) <-> 172.28.19.252(80)
1363006712.5002 (0.0010)  C>S
GET / HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: elmdemo.access.com
Accept: */*
New TCP connection 2: 200.200.200.10(43427) <-> 200.200.200.101(6000)
1363006712.5010 (0.0006)  C>S
GET /elmdemo/sighno.html HTTP/1.1
Host: elmdemo1.access.com
Accept: */*
This is a very good scenario for ProxyPass (DevCentral - An F5 Technical Community).
Here is my curent Irule. I just don’t want the users browser to show anything bu http://elmdev.accessmidstream.net. Sorry had to change to Dev pool for testing. So user types in http://elmdev.accessmidstream.net adn it redirects to http://elmdev1.accessmidstream.net:6000/elmdev/signon.html but I don’t want user to know that they have been redirected.
if { [HTTP::path] equals “/” } {
HTTP::redirect “http://elmdev1.accessmidstream.net:6000/elmdev/signon.html”
As nitass indicated, At the very least the HTTP::header replace Host and HTTP::uri commands will transparently change the Hosts header and URI on the ingress flow. The HTTP::redirect command sends the user a physical 302 redirect (which alters the browser URL). There are some potentially dangerous assumptions being made though:
1. Any request for “/” will need to be redirected to “/elmdev/signon.html”
3. The application server isn’t sending back any references to its physical location and paths in references to embedded objects and redirects
For a more robust solution that handles all of the translations between the client side and server side (hosts, port, URIs, pools, etc.), please take a look at the ProxyPass iRule.
Can someone give an example of how to configure proxy pass for this?
All of the documentation and some config examples are embedded in the ProxyPass iRule.
Essentially you’ll load up and apply the iRule, then create a data group of a specific name that contains the public and private side mappings.
