Irule to use respective client-ssl profiles for the multiple applications hosted on the same VIP.
Hello Team,
We have an existing application setup running with multiple applications using the same VIP 1.2.3.4.
eg: a.xyz.com - 1.2.3.4. - Pool A b.xyz.com - 1.2.3.4. - Pool B c.xyz.com - 1.2.3.4. - Pool C d.xyz.com - 1.2.3.4. - Pool D
Now we are planning to use SSL connection for the applications to use individual respective certs instead of a global or domain certificate. (*.xyz.com), is this possible to configure using irule , to use respective client-ssl profile for the respective applications configured in the same VIP ?
  • SAM
isn’t it done by sni?
sol13452: Configuring a virtual server to serve multiple HTTPS sites using the TLS Server Name Indication feature
for selecting pool based on host header, you can use irule or local traffic policies.
sol9800: Using an iRule to load balance HTTP requests to multiple pools
sol15097: Using the Local Traffic Policies feature to load balance HTTP requests to multiple pools
