iRule to start conditionnaly oneconnect
Is it possible to create an iRule that would match some specific clients source IP address (WAF farm) and apply accordingly a oneConnect profil ?
Idea is to enable connection reuse only for WAF servers (persist on XFF) but not for other basic clients (persist on sourceIP).
a try :
when CLIENT_ACCEPTED { if {[IP::addr [IP::client_addr] equals 10.2.0.0/16]} { onconnect myOneConnect <==== this -of course- does not works :frowning: } }
Hi Gilles, Have you taken a look at the following post?
-=Bhattman=-
Thank you for the reply…
so the idea is to associate a OneConnect profil to the virtual server and disable the connection reuse when client does not match the expected source :
    if { not( [IP::addr [IP::client_addr] equals 10.2.0.0/16] ) } {
        ONECONNECT::reuse disable
Correct ?
