Have you seen this question? It may help a little bit (though I don’t know if you can “set” the whereis value (unless you know of an IP in the expected country and use that instead of IP::client_addr).
Perhaps the safest option would be expanding your IF condition with an OR statement (using the [IP::client_addr] function, as recommended by Michael J)
if { ([whereis [IP::client_addr]] == "CN") || ([IP::client_addr] == "Your.IP.Address" ) } {
do some stuff...
Alternatively, you should be able to set the system-provided ‘whereis’ variable to your own value. Have not tested, please use with caution
if { [IP::client_addr] == "Your.IP.Address"} {
set [whereis [IP::client_addr]] "CN"
For verification, tail /var/log/ltm as you implement the changes
log local0. "IP: [IP::client_addr]; Country Code: [whereis [IP::client_addr]]"
Geo-location iRule continues...
I’m pretty sure that the whereis function is read-only, so you can’t do any kind of setting the value. Based on your original question of wanting to test, then your best bet may be to just use a variable and set it manually
if {[IP::client_addr] == "Your.IP.Address"} {
set country "CN"
set country [whereis [IP::client_addr] country]
log local0. "IP: [IP::client_addr]; Country Code: $country"
Use the "$country" variable instead of "whereis" from now on.
