we have a virtual server mapping to a pool with one apache web node.
client wants to test the new node via the virtual server.
Can we craft an iRule to direct her session to the new pool/node based on a cookie/env variable she sets beforehand ? (and then reset her session routing back to production after her testing is done?) (I imagine this kind of scheme could also integrate with the app itself so the app say picks up the cookie and announces when its in test mode)
Can someone please point me at an example of this or suggest a better way to do this with our BigIPs? (BIG-IP 10.2.1 Build 511.0 Hotfix HF3)
You could add the new member at a lower priority and then use an iRule like this to allow manual selection of it with a query string parameter and cookie:
When you’re done testing, change the priority of the new pool member to the same as the other one to have it used in normal load balancing.
Or as Brian said, if you can filter by client IP, it would be simpler to do something like this:
when CLIENT_ACCEPTED {
if {[IP::addr [IP::client_addr] equals 1.1.1.1]}{
node 10.1.1.1 80
With this simple iRule you don’t even need to add the new member to the pool. When you’re done testing, just remove the iRule and add the new member to the pool.
I agree with Brian. Filtering and routing on the Client IP Address is the easiest solution. If you have more than one IP Address to filter on / route to test this node then I would suggest using a Data Group.
Something like this:
if { [IP::client_addr] equals "10.10.10.10" } {
node 20.20.20.20 80
Are clients going through a proxy to get to the virtual server? If you take the iRule off, do you see the same issue with pool member selection?
Can you try adding a OneConnect profile to the virtual server? if you’re using SNAT on the serverside you can use the default OneConnect profile with a /0 source mask. Else, create a custom OneConnect profile with a /32 source mask.
If using OneConnect and the iRule doesn’t fix the issue, can you enable debug in the HTTP_REQUEST event and reply with anonymized logs from /var/log/ltm?
" If you take the iRule off, do you see the same issue with pool member selection?"
NO
Looks like a bug in the iRule - I removed the iRule and the Priority Group was perfectly obeyed - as soon as I put it back in, the test node received traffic…(without member=
I tried this 2-3 times and reproduced the issue each time.
