iRule to require client certificate and validate it
I have limited possibilities to test the iRule because the business application is running via the F5… so can anyone help with this code (if there is no obvious syntax error):
if { [HTTP::uri] starts_with “/pattern” }
{HTTP::collect
SSL::cert mode require
SSL::renegotiate
set ssl_cert [SSL::cert 0]
set isMatch 0
set org “Company name”
set locality “Warszawa”
set name “www.f5.com.pl”
set country “PL”
set issorg ““Thawte Consulting (Pty) Ltd.”
set isscn “Thawte SGC C”
set issctr “PL”
set subject_dn [X509::subject $ssl_cert]
set issuer_dn [X509::issuer $ssl_cert]
log “Client Certificate Received: $subject_dn, $issuer_dn”
if { ($subject_dn matches $org) and ($subject_dn matches $locality) and ($subject_dn matches $name) and ($subject_dn matches $country) and ($issuer_dn matches $issorg) and ($issuer_dn matches $isscn) and ($issuer_dn matches $issctr)}
log “Client Certificate Accepted: $subject_dn, $issuer_dn”
set isMatch 1
pool TestSSL}
if { $isMatch == 0 }
log “No Matching Client Certificate Was Found Using: $subject_dn”
reject
else
pool TEST
What do you mean “help” with this code? Is it not working? How is it behaving? What is it you’re trying to accomplish from a big picture?
Colin
lol pwned
hi,
I have just checked that this version (below) is able to compile on F5:
if { [HTTP::uri] starts_with “/pattern” } {
HTTP::collect
SSL::renegotiate
set isMatch 0
set name “www.f5.net”
set country “PL”
set issctr “Us”
if { [$subject_dn matches $org] and [$subject_dn matches $locality] and [$subject_dn matches $name] and [$subject_dn matches $country] and [$issuer_dn matches $issorg] and [$issuer_dn matches $isscn] and [$issuer_dn matches $issctr] } {
set isMatch 1
pool TestSSL
if { $isMatch == 0 }{
reject
else {
pool TEST
but question is:
I want that script to:
1. check for each HTTP connection the URI if it starts with “/pattern”
2. if pattern match require client certificate
3. if client has certificate check the specified record from X.509 cert
I have limited possibilities and not much time to test it on F5, thus I would like to prepare the script as good as possible to decrease number of iteration during test phase.
and the question is if someone more experienced in scripting could tell if this script has a chances to work as planned.
Jarrod, you joined just to add “owned”? That’s helpful…
l.majewski, if you want to require a client cert only for specific URIs, you’re close. Try checking these related posts for some examples and reply here if you run into any issues.
iRule to require SSL Client Certs for a URI (Click here)
if no cert rule (Click here)
Also, if you have access to the BIG-IP, but can’t modify the production virtual servers, you might try adding a test VIP on a separate IP/port or the same IP and different port.
Aaron
It is partially working. When the first “if” is true (URI match) then browser is displaying the message with certificates, I choose cert stored on my chip card. Then the PIN window appear, I enter the PIN code to the cert and then on the browser is message cannot display page. In the log generated by script itself there is entry NO cert. I tried even for this code proposed by F5: (I always get the message log:
“No cert found. Holding HTTP request until a client cert is presented…”
when CLIENT_ACCEPTED {
set session_flag 0
when CLIENTSSL_HANDSHAKE {
if { [SSL::cert count] != 0 } {
log “Client cert is OK; releasing HTTP request.”
HTTP::release
if { [HTTP::uri] starts_with “/polcard/” } {
log “Certificate required for: [HTTP::uri]”
if { [SSL::cert count] == 0} {
log “No cert found. Holding HTTP request until a client cert is presented…”
HTTP::collect
set session_flag 1
SSL::authenticate always
SSL::authenticate depth 9
SSL::renegotiate
else {
log “crt OK”
pool TestSSL
HTTP::release
else {
log “No certificate needed for: [HTTP::uri]”
pool Test
It looks like my cert cannot be retrieved from chip card. I use the same card and the same cert to authenticate on another web server and it is working. What is wrong??
L,
The code looks good, and indeed, worked just fine for me. I tested using the default software store on Mozilla (which also requires a password).
Make sure that your clientssl profile lists the CA in the “client cert ca” attribute.
I have code is similar to what mentioned earlier
when CLIENT_ACCEPTED { set session_flag 0 } when CLIENTSSL_HANDSHAKE { if { [SSL::cert count] != 0 } { log “Client cert is OK; releasing HTTP request.” HTTP::release } } when HTTP_REQUEST { if { [HTTP::uri] starts_with “/polcard/” } { log “Certificate required for: [HTTP::uri]” if { [SSL::cert count] == 0} { log “No cert found. Holding HTTP request until a client cert is presented…” HTTP::collect set session_flag 1 SSL::authenticate always SSL::authenticate depth 9 SSL::cert mode require SSL::renegotiate } else { log “crt OK” pool TestSSL HTTP::release } } else { log “No certificate needed for: [HTTP::uri]” pool Test } }
