All,
I have an iOS app (qlikview 2.1) that is sometimes sending the NetBIOS-Name rather than the sAMAccountName. I am trying to create an iRule to check for this and do a replacement. I am receiving the following error when saving the iRule:
01070151:3: Rule [/Common/qlikview_username_fix] error: /Common/qlikview_username_fix:7: error: [wrong args][HTTP::username replace “$username” “$user”]
Has anyone done this and what am I doing wrong?
Here is my iRule: when HTTP_REQUEST {
if {[string tolower [HTTP::username]] starts_with “domainname”} { set username [string tolower [HTTP::username]] set user [getfield $username “/” 2] set domain [getfield $username “/” 1] HTTP::username replace $username $user} }
Thank you
According to the wiki page for HTTP::username, it’s a read-only command, so you can’t update the username with that command. Here’s spin off of what I’ve done in the past that may work for you:
if { [HTTP::header exists "Authorization"] && [HTTP::header value "Authorization"] starts_with "Basic " } {
Basic Authentication
log local0. " Authorization: [HTTP::header value "Authorization"]"
log local0. " Username: [HTTP::username]"
log local0. " Password: [HTTP::password]"
Parse the username
set user [getfield [string tolower [HTTP::username]] "\" 2]
Recreate the Authorization header
set newAuth "${user}:[HTTP::password]"
set newAuthEnc [b64encode $newAuth]
HTTP::header replace "Authorization" "Basic $newAuthEnc"
Remove the variables
unset newAuth
unset newAuthEnc
unset user
NOTE: I saw you were using
in your
getfield
command. Was that intentional or did you mean to user
which is used for domain\username notation?
With the help from F5 support, I found a way to fix this in the VPE…I added a check to see if session.logon.last.username starts_with “domain”:
If true, do variable assign prior to AD auth: Custom Variable: session.logon.last.username Custom Expression: return [lindex [split [mcget {session.logon.last.username}] “/”] 1]
If false, do AD auth.
This seems to work.
