This has got to be simple but I can’t figure it out!!
Can anyone help me to write an iRule that will reference a data group list of IP addresses I want to whitelist on ASM? I don’t want to deny IP’s that aren’t on the list, just to never block those on the list.
you can try something like this… Not tested yet. Please test in non prod device.
when CLIENT_ACCEPTED {
if {[matchclass [IP::client_addr] equals bypass_asm_class]}{
set disable_asm 1
#log local0. "[IP::client_addr]:[TCP::client_port]: Client matched bypass_asm_class datagroup."
set disable_asm 0
#log local0. "[IP::client_addr]:[TCP::client_port]: Client did not match bypass_asm_class datagroup."
when HTTP_CLASS_SELECTED {
if {[HTTP::class asm]==1}{
if {$disable_asm==1}{
log local0. "[IP::client_addr]:[TCP::client_port]: Disabling ASM for this request."
ASM::disable
log local0. "[IP::client_addr]:[TCP::client_port]: Not disabling ASM for this request."
ASM::enable
Set the log according to requirements and later disable it
The HTTP_CLASS_SELECTED event has been deprecated. Instead, you can use a local traffic policy to selectively enable and disable ASM, as Samir showed, using an IP address data group to make the comparisons. For example:
It’s important that the catch-all rule, enable_asm_for_all_traffic, be the second rule in the policy, and disable_asm_for_select_IPs be first. You would assign the local traffic policy to the appropriate virtual server, replacing the default one applied when you enable an application security policy on the virtual server.
Here is what my internal datagroup looks like. (You can use an external data group just as easily.):
ltm data-group internal no_ASM_IPs {
records {
10.10.10.30/32 { }
type ip
You can log the unblocked requests from within the local traffic policy. (I had log statements in both my rules, but removed them for the answer above.) There is a log action that can be added on the disable ASM rule. For example:
