Hello,
I need to redirect traffic from VS_prospect to a specific node(prospect) if the uri begin whith /NECPF/vod/cpprospect/. VS_prospect is in partition CLI05_SFR and node prospect in partition CLI03_INTE. I create in partition CLI03_INTE a pool that i named pool_prospect whith pool member the node prospect.
My VS have as ressource a default pool named POOL_RP_ADSL to which all traffic is directed. My idea is to add an irule to VS_prospect to direct the traffic to pool_prospect if the uri begin whith /NECPF/vod/cpprospect/. Is it a correct method?
Here is the irule that i create:
if { [HTTP::uri] contains "^/NECPF/vod/cpprospect/*" } {
pool /CLI03_INTE/pool_prospect
is the syntax and condition correct? if yes, i will attach this irule to VS_Prospect.Do the traffic be directed to pool_prospect instead of the default pool as expected?
Advice please, it is for production environment!
