Irule to redirect traffic based on path and uri
I have to redirect some traffic based on path and other based on uri. The irule should look something like this, but it´s not working. I should get working something like I post below. Any help?
when HTTP_REQUEST { switch -glob [string tolower [HTTP::uri]] { “/bla/blabla.gif” { pool pool-frontend } if { [HTTP::path } “/bla*” { pool pool-frontend2 } … … …
Thanks in advance and regards, Pablo.
Why don’t you use LTM policies, essentially F5 created these to make http parsing easy and not to need to code an irule… take a look its pretty self explanatory
Your question is a bit vague, but this might push you in the right direction.
    Set a variable to control if a pool has been chosen or not.
    set chosen 0
    switch [string tolower [HTTP::uri]] {
        "/bla/blabla.gif" { set chosen 1; pool pool-frontend }
    Check if the switch has chosen a pool
    if { $chosen != 1 } {
        if { [HTTP::path] starts_with "/bla" } {
            pool pool-frontend2
            pool default_pool
Please note that I have not tested the rule myself.
/Patrik
Why not use the switch function for it all. I believe the switch command uses the first match so you could do:
            "/bla/blabla.gif" { pool pool-frontend }
            "/bla*" {pool pool-frontend2}
            default {pool default}
