iRule to redirect for specific uri
We want if customer request https://abc.com/login then it gets redirected to https://abc.com/login?local=true
I wrote below iRule
    set lowerCaseHost [ string tolower [HTTP::host] ]
    set lowerCaseUri [string tolower [HTTP::uri]]
    if { $lowerCaseUri equals "/login" } {
    HTTP::redirect "https://abc.com/login?local=true"
            return
it is working… But when customer types only https://abc.com then also it gets redirected to https://abc.com/login?local=true we want redirection should happen only for https://abc.com/login Not sure whats wrong with this iRule. Please suggest.
Hi
you may try the snippet belowe to differentiate between the different host names…
    if { [string tolower [HTTP::uri]] equals "/login" } then {
        if { [string tolower [HTTP::host]] equals "abc.de" } then {
            return
            HTTP::redirect "https://www.abc.com/login?local=true"
            return
Note: I’ve removed the $lowerCaseHost and $lowerCaseUri variables because of performance reasons. Well, it make sense to use those variables, but just if you need the value more than once… :wink:
Cheers, Kai
