Hi all, I’m trying to write a rule that will search the first 2500 bytes of tcp_content for the “USERNAME=” string and then persist on the next 7 characters after that. Here is my original attempt.
rule client_tcpusrid_persist {
when CLIENT_ACCEPTED {
set usrid {findstr [tcp_content(2500) contains "USERNAME="] "USERNAME=" 7 "t"}
if {tcp_content(2500) contains "USERNAME="} {
persist uie $usrid
log local0. "Persisting $userid"
The first is that it appears you have typed the “rule {” portion into the GUI text box. When entering rules in the GUI, you must leave out the “rule {}” part of the rule. You enter the at the top and then enter the rule body (the when statements) in the text box.
When this gets saved into the config file, it then appears with the “rule {…}” part automatically added.
The second problem is how tcp_content now works in 9.0. In order for the tcp_content (which is really now called TCP::payload) to work, you must first specify how much you want to collect. In your case, it appears that you want to collect 2500 bytes. So, a rule that gathers 2500 bytes would look like this:
TCP::collect 2500
when CLIENT_DATA {
set usrid [findstr [TCP::payload] "USERNAME=" 9 "t"]
if {$usrid ne ""} {
persist uie $usrid
The 9 and the “t” tell it to start 9 bytes after “USERNAME=” (since it’s 9 bytes long) and stop at “t”. This way it’s reading “s009999” which is the userid I want to persist on. The value in the “t” position can be what ever fits for you. For the streams I’m looking at they are separted by “t..”.
Jason, I was following your issue with the MSRDP and found it indeed very interesting and was myself quite impressed by the powers of iRules.
However another question rather basic perhaps ?
Can you guys tell me what happens in the case of the first TCP::collect, does this execute indefinitely for a TCP connection seen as the TCP::release is for the inner event :
Do not declare the rule in the script this is just for clarity
rule NonKeep-alivePersistence {
Rule entry point
TCP::collect
when CLIENT_DATA {
TCP::collect 25
log local0. "persisting:"
set hashKey [findstr [TCP::payload] "X-Client-IP" 13 "\r"]
if the hashKey is not equal to a whitespace/delimiter
if {$hashKey ne ""} {
persist uie $hashKey 1200
pool TestPool
log local0. "Key to persist: $hashKey"
Flush collect data and release event hook point
TCP::release
Finally and most importantly the event ClIENT_DATA when used without CLIENT_ACCEPTED does not seem to turn on its own. I got nothing in the snoop or the logs. Can I use CLIENT_DATA to check the data payload of a TCP connection without executing the event on the connection set-up (CLIENT_ACCEPTED) Of course this is crucial if I want to use keep-alive.
Can you inspect a server response on TCP level, retrieve a value, modify it and send back to client? I need to get the value of a Max-Connections header from a server in an options response. Modify this value to insert the total Max-Connections value for all the servers in the pool and send it on its way back to the client.
I got the impression from forum that the Wizards like to see a little effort or a hack at a rule from the subscriber so here goes: (its not pretty!)
Rule entry point
when SERVER_CONNECTED {
TCP::collect
when SERVER_DATA {
Collect 30 bytes to see if its an OPTIONS response
TCP::collect 30
set identifier [findstr [TCP::payload] "OPTIONS" 7 "\r"]
if {$identifier ne " "} {
if its an OPTIONS response, process the TCP..
TCP::collect 250
250 bytes should give me the Max-Connections header
} else { [[TCP::payload] contains "Max-Connections:"]} {
set MaxConn [[TCP::payload] value "Max-Connections:"]
TCP::respond $MaxConn
log local0. "OptionResponse: $MaxConn"
TCP::release
The “Max-Connections: 2000\r\n” header is very simple and tells me how mant TCP connections I can set up on my server.
I am a little bit weary of TCP::respond, for the moment I have not managed to retrieve the value of Max-Connections.
Finally I need to be able to modify this value for example by a factor of 10 and return this value to the client.
In the particular example above, you do not need the TCP::release because there is an implied release if a new collect was not issued in the CLIENT_DATA event. However, doing the TCP::release is certainly not harmful in any way.
Anybody going to take a crack at cleaning up Vinny’s rule? He did at least hack something together…
Some hints:
A) You probably only want to do the TCP::collect 250 once in the SERVER_CONNECTED event (you can then get rid of all the TCP::collect’s in the SERVER_DATA event).
B) Don’t use TCP::respond here as it will provide a response to the server. What you will want to do is use:
I was hoping you would reply, I like’d your work on the MSRDP problem.
Here’s the thing, I have 3 different pools of Servers (3 services) I have client infor in the X-Client-IP header (you can refer to my original post,5:07AM) The rule I developed works fine on non persistent TCP as there is only going to be one request with one X-Client-IP in a TCP connection. However when enabling keep-alive and manipulating the appropriate offsets and carriage returns it does not fire.
Can I use Client data on its own without a client accepted event, how can I loop within the client accepted to retrieve all possible X-Client-IPs in a keep-alive TCP. Here’s my hack at it:
TCP::collect
when CLIENT_DATA {
For requests arriving using a Content-Length header
if { [TCP::payload contains "Content-Length:"] } {
set ConLen [TCP::payload value "Content-Length:"]
} else { [TCP::payload contains "Encapsulated: req-hdr="] } {
set hdrStart [TCP::payload value "Encapsulated: req-hdr="]
set hashKey1 [findstr [TCP::payload] "X-Client-IP" 13 "\r"]
if {$hashKey1 ne ""} {
persist uie $hashKey1 1200
} elseif { [TCP::payload contains "Encapsulated: req-hdr=0, null-body="] } {
set hdrOSet [TCP::payload value "Encapsulated: req-hdr=0, null-body="]
set hashKey2 [findstr [TCP::payload] "X-Client-IP" 13 "\r"]
if {$hashKey2 ne ""} {
persist uie $hashKey2 1200
TCP::release
As you can see it gets a little complicated with the offsets, so I just want to precise exactly the offset values:
Encapsulated: req-hdr=0, req-body=412
The request header starts at 0 and the body at 412 bytes.
Encapsulated: req-hdr=0, null-body=412
The request header is 412 bytes, there is no request body.
The BIP is 9.0.4 I would also appreciate a little help on the server response problem.
Wow, that is some complicated iRule you’ve developed…
I see a couple of problems. First, is that you do this:
I’m not sure what you are expecting this to do (and I’m surprised it’s not giving you an error). Assuming you want to extract the value of the Content-Length, you more likely want to do this:
set ConLen [findstr [TCP::payload] "Content-Length:" 15 "\r"]
The other aspect to understand is that data will not be sent to the server until you issue the TCP::release. However, you may also re-issue a new TCP::collect which will then further collect more data and re-trigger the CLIENT_DATA event. So, it sounds like you would want to determine the size of the initial request, TCP::release that amount and then do another TCP::collect and keep doing that until the connection is closed.
However, here’s another question: How come you can’t just use the HTTP profile and then trigger off the HTTP_REQUEST event which already parses HTTP requests/responses? Or is this some non-HTTP protocol?
