Hi iRule noob … Is it possible to construct a cunning iRule which monitors servers that are not in a pool, but the servers IN the pool are dependent on these downstream servers [I think Oracle db] being up and active ?
Thanks in advance
Thanks in advance
Using iRule SIDEBAND you can “interact” with external server/service (check availability in your scenario):
But in my opinion the best choice is to create an external monitor that will do monitoring of your external server and apply to pool members.
You don’t have to check external server availability for every connections you receive on VS, so an external monitor will be a good solution.
Another possibility is to write a healthcheck in whatever language on the web/application server, which also checks the backend database and use this healthcheck on the pool. Then, your backend server will be active only when also the database is OK.
So, for example:
So, for example:
Thanks but I need to keep the monitoring local to the F5 - the servers and how they operate are controlled by another company.
Best way to do is configure a monitor with Alias IP and make it transparent. In alias IP sepecify external server IP and assign the monitor to pool member or pool as per your requirement.
