iRule to modify part of IP::client_addr
I’m trying to use an iRule to modify the client_addr to use as the snat.
client IP = 10.10.10.201 desired NAT = 192.168.1.201
Something like:
if { [matchclass [IP::client_addr] equals NAT_Clients]} {
snat using this source address
     snat 192.168.1.$current_host_ip_last_octet
How would one go about doing that? using set and concat?
set lastoctet [getfield [IP::client_addr] “.” 4]
Should do the trick for you
Hi Agehring,
you may try the syntax below…
snat "192.168.1.[getfield [IP::client_addr] "." 4]"
Cheers, Kai
