I am new with Irules formulation and i have a requirement base on the subject.
I have a current virtual server acceppting HTTPS from the internet and redirect the web traffic via HTTP in my http pool. but a new requirement to protect the customer information communication from BIGIP 8800 to our Web servers by redirecting customer login URL to our WEb servers via HTTPS using https_pool. How can i achieve this requirement using the existing virtual server.
Many thanks in advance for your time looking on my issues.
This shouldn’t be a problem. Have a look here for some of your options: http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=14536
In particular, look at hoolio’s first example which shows you how to selectively disable ssl (you can just as easily *enable* it as well) based on uri:
Pasted from http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=14536
Check if request matches the criteria to disable server-side SSL
if { [HTTP::uri] starts_with "/clear"}{
disable SSL on the serverside context
SSL::disable serverside
select the http pool
pool http_pool
default is to use server-side SSL and the https pool
pool https_pool
Be sure and read the whole thread as it’s got a bunch of good stuff in it and it’ll give you a feel for some of the options available to you.
-Matt
Thanks Matt for the response, I will try to create an irule that have a similar setup and do testing.
Give you feedback on the result.
Regards
