Irule to Load Balance traffic based on group of IP's
I would like to write an Irule to basically say “if a group of IP’s come into the VIP, load balance to server 1 and 2, all others hit server 3” I’m newish to Irules so would like some help please.
There are a few ways to deal with this, but one example is to use an iRule data group and match the specific source IP and make a decision based on that. I would set this up using two pools, a data group and a rule as per this example:
Pool1 - Server 1 and 2 Pool2 - Server 3
iRule Data group (String type)
Add the IP Addresses to route to Pool1
iRule to direct the traffic:
    if {[class match [IP::client_addr] equals Pool1IPs} {
        Pool Pool1
        Pool Pool2
Hello,
You can use list directly in the irule as shown in the example below :
when RULE_INIT {
    set static::ipaddress ["10.1.1.1" "10.1.1.2" "10.1.1.3"]
    if { [lsearch -glob $static::ipaddress "[IP::client_addr]"] != -1 } {
        pool mypool
        pool default_pool
