irule to load balance to specific ISP based on source IP
hi guys,
i have 2 ISP links and i’m doing outbound load balancing across the 2 links. i have 2 subnets of users, subnet 1 and subnet 2. I need that subnet 1 go through ISP 1 and subnet 2 go through ISP 2. in case of ISP 1 down, subnet 1 go through ISP 2 and subnet 2 stop going internet. the vice versa is not correct, i mean if ISP 2 down, subnet 2 will not have internet. i mean always subnet 1 have priority to go internet. i need irule to do this scenario.
Create 2 pools :
  • Pool_GW_ISP1
    • priority group activation : less than 1
    • ISP1_GW:0 priority 10
    • ISP2_GW:0 priority 1
  • Pool_GW_ISP2
    • ISP2_GW:0 priority 10
create 2 VS
  • VS_FWD_OUT_SUBNET1
    • source : SUBNET1 (ex : 10.1.0.0/16)
    • destination : 0.0.0.0/0
    • service : any
    • translate address : disable
    • pool Pool_GW_ISP1
    • source address translation : automap
  • VS_FWD_OUT_SUBNET2
    • source : SUBNET2 (ex : 10.2.0.0/16)
    • service : any
    • pool Pool_GW_ISP2
First create a ISP pool. Based on source IP and port you can send traffic to specific pool.
when CLIENT_ACCEPTED { if {[IP::addr [IP::client_addr] equals 10.x.x.x] or [IP::addr [IP::client_addr] equals 192.x.x.x]} { if { [TCP::local_port] == 443 } { pool ISP-POOL } else { reject } } else { reject } }
Hi Hawary,
you may use the iRule below on your
IP-Forwarding
Virtual Server, to overwrite the SNAT and Nexthop-IP based on the availability of the Def-GW for ISP1.
  • If ISP1 is available it will route traffic from Network 1 to ISP1
  • If ISP1 is available it will route traffic from Network 2 to ISP2
  • If ISP1 is offline it will route traffic from Network 1 to ISP2
  • If ISP1 is offline it will reject traffic from Network 2
Note: You don’t have to care if ISP2 is offline - simply try to send traffic to ISP2 as gateway of last resort and see what happens. If ISP2 is down the traffic will be dropped anyway…
    if { [IP::addr [IP::client_addr] 10.10.10.0/24] } then {
         Section for Network 1
        if { [active_members GW_ISP_1_POOL] > 0 } then {
             ISP 1 is online. Use VS default settings and local routing table.
             ISP 1 is offline. Setting SNAT IP and Nexthop (aka. routing table overwrite) to ISP2
            snat 222.222.222.10 ; Your IP for ISP2
            nexthop 222.222.222.1   ; Def-GW of ISP2
    } elseif { [IP::addr [IP::client_addr] 10.20.20.0/24] } then {
         Section for Network 2
             ISP 1 is online. Setting SNAT IP and Nexthop (aka. routing table overwrite) to ISP2
             ISP 1 is offline. Reject access for Network 2.
            reject
         Undefined traffic will use VS default settings...
Note: If you utilize theVirtual Server for internal communication too, then define some additional exceptions for your internal destination IPs (e.g. RFC1918 IPs) at the top of the script, so that the/overwrites will have no effect on those connections.
IP-Forwarding
snat
nexthop
Cheers, Kai
