iRule to load balance based on source IP
Hi Folks, This is my first attempt at an iRule so I wanted to bounce it off all of you for comment. There are, no doubt, syntax and logic errors.
The purpose of this iRule is to load balance based on the source IP address’s third octet. If it’s odd, then we go to pool member 1. If its even, to pool member 2. In this particular case, the session is ssl encrypted through the F5 so I cannot use a cookie or other persistence method. I am left with just the src and dest IP and an encrypted data packet to work with. Since the application requires some form of persistence, load balancing based on the IP address seems to be the best possibility.
when CLIENT_ACCEPTED { ! Use getfield to pull the source IP address’s third octet and determine if its even or odd. set third-octet [expr {[getfield [IP::client_addr] “.” 3]}] if { [$third-octet ends_with 0,2,4,6,8] { set destination even } elseif { set destination odd } }
! Send even sources to one Pool member, odds to the other.
if { [$destination eq odd]
  pool Application-pool member server1 80
    persist source_addr 14400
if { [$destination eq even]
  pool Application-pool member server2 80
!If a pool member is not available, send the session back to the Pool and set the persistence
!for a 60 minute timeout
when LB_FAILED { pool Application-pool persist source_addr 3600 LB::reselect }
There are a few things I’m not sure are going to work right, particularly the ends_with on line 4 to determine if the $third-octet is even or odd. I’m also not sure if I need the expr on line 3 when I’m setting the third-octet variable.
Many thanks in advance.
Simon Coffin
Let’s try that again with better formatting.
  ! Use getfield to pull the source IP address's third octet and determine if its
  ! even or odd.
  set third-octet [expr {[getfield [IP::client_addr] "." 3]}]
    elseif
  !set the persistence for a 60 minute timeout
when LB_FAILED {
i understand pool member command won’t create persistence record.
e.g.
config
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:80
    ip-protocol tcp
    mask 255.255.255.255
    pool foo
    profiles {
        http { }
        tcp { }
    rules {
        qux
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 68
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:80 {
            address 200.200.200.101
        200.200.200.111:80 {
            address 200.200.200.111
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
  pool foo member 200.200.200.101 80
 test
[root@centos1 ~] curl -I http://172.28.24.10
HTTP/1.1 200 OK
Date: Thu, 21 Aug 2014 01:45:23 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Content-Type: text/html; charset=UTF-8
 persistence record
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show ltm persistence persist-records
Sys::Persistent Connections
Total records returned: 0
so, you may have to manually lookup and add persistence record in the irule.
e.g.
config
ltm rule qux {
  if { [persist lookup source_addr [IP::client_addr]] ne "" } {
when SERVER_CONNECTED {
  persist add source_addr [IP::client_addr] 14400
when LB_FAILED {
  LB::reselect pool foo
 test
HTTP/1.1 200 OK
Date: Thu, 21 Aug 2014 01:47:03 GMT
Content-Length: 89
 persistence record
source-address  172.28.24.1  172.28.24.10:80  200.200.200.101:80  (tmm: 0)
source-address  172.28.24.1  172.28.24.10:80  200.200.200.101:80  (tmm: 1)
Total records returned: 2
