Irule to laod balance based on soap session ID
Hi
I have a request to search a soap message for the session ID. Based on the first 2 values in the ID I will then need to send the request to a pool member. Below is an example of the message. If the starts with 01 then go to pool member 1. If the starts with 02 then go to pool member 2. if there is no 01 or 02 then load balance normally(round robin) across the 2 servers .
Any assistance will be helpful
http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC=“http://schemas.xmlsoap.org/soap/encoding/” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xmlns:xsd=“http://www.w3.org/2001/XMLSchema”>http://www.eskom.co.za/IAM\_MyEskom/">MYCOMPACUST01S1441888421150m4j07NyGit506Z377zDe81FHkA0U0yO9iibnFXUN8852755my@gmail.com
Hi
You would probably need to do something with HTTP::collect to get the payload so you can search it and find the string.
Collect a request payload
  if {[HTTP::method] eq "POST"}{
     Trigger collection for up to 1MB of data
    if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{
      set content_length [HTTP::header "Content-Length"]
        set content_length 1048576
     Check if $content_length is not set to 0
    if { $content_length > 0} {
      HTTP::collect $content_length
when HTTP_REQUEST_DATA {
   do stuff with the payload
  set payload [HTTP::payload]
From there, you would want to manually specify the pool member to route the request to (see here). Something like this in the HTTP_REQUEST_DATA event:
if { $payload contains "01" } {
  node 10.0.0.1 80
} else if {$payload contains "02"} {
   I forget if it's "elseif" or "else if"
  node 10.0.0.2 80
Then, if you don’t have either, it’ll load balance as normal.
There’s an XML profile you can use see link https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/ltm_implementation/sol_xml_cbr.html. It’s for v10.x but I believe still applies in 11.x.
