iRule experts,
I am trying to implement an iRule that would basically do redirections based on the uri.
Pool1:
xxx.xxx.xxx.111:8000
xxx.xxx.xxx.222:8000
Pool2:
xxx.xxx.xxx.111:9000
xxx.xxx.xxx.222:9000
https://abc.com/business --> this should redirect to Pool1
https://abc.com/ --> this should redirect to Pool2
Thanks!
if { [HTTP::uri] starts_with "/business" } {
pool pool_1
pool pool_2
where “pool_1” and “pool_2” are the names of your respective pools.
Or, if you have the default pool set to pool_2 in your http profile, you could omit the else statement and just override the default for your /business requests
pool pool_1
PS, love the avatar!
-Joe
No problem and glad to help.
-Joe
I have a similiar challenge. What I would like to do is have a https VIP using different certs based on URI.
Example:
IP: 10.123.123.1 = VIP
cert1 = www.abc.com > pool1
cert2 = test.abc.com > pool2
cert3 = www.cde.com > pool3
I would like to use irules to use different certs for different sites, and of course direct the traffic to the relevent pool.
Doesn’t work for HTTPS.
Short explanation here: DevCentral - An F5 Technical Community (Click here)
I’d suggest moving this request over to the iRules forum for better visibility.
-Joe
To clarify, since your question had 2 parts:
If you are terminating traffic @ LTM, you can distribute to different pools by hostname or URI.
However, you can’t choose a different cert because the info is received too late -- see above link for short explanation.
