irule to extract single IP from X-Forwarded-for results with multiple IPs
I need an irule to split the IP::remote_addr and just set the first IP as theX-Forwarded-For
when HTTP_REQUEST { HTTP::header insert X-Forwarded-For [IP::remote_addr] }
DevCentral - An F5 Technical Community Is almost there with the following but it doesn’t apply after the “foreach” line(they were trying to something different though in the end):
if {[HTTP::header “X-Forwarded-For”] ne “”}{
log local0. "XFF: [HTTP::header "X-Forwarded-For"]"
  foreach xff [split [string map [list " " ""] [HTTP::header "X-Forwarded-For"]] ","] {
 log local0. "Current XFF element: $xff"
 if {[IP::addr $xff equals 1.2.3.4]}{
        log local0. "Sending 410 for $xff"
        HTTP::respond 410
        break
Can you clarify? How would IP::remote_addr contain multiple addresses? The XFF header might, but IP::remote_addr gets its information from the TCP packet.
XFF is returning IP,IP sometimes. Is there a way to split that out and send just first listed IP?
Ah, ok. Wasn’t sure how [IP::remote_addr] was involved.
An X-Forwarded-For header with multiple IPs will be comma-delimited:
X-Forwarded-For: 10.10.0.1, 10.10.0.2, 10.10.0.3
So to grab the first one, you can do some simple list manipulation:
if { [HTTP::header "X-Forwarded-For"] ne "" } {
    if { [HTTP::header "X-Forwarded-For"] contains "," }{
        set ips [split [HTTP::header "X-Forwarded-For"] ","]
        set xff [lindex ${ips} 0]
        set xff [HTTP::header "X-Forwarded-For"]
    set xff [IP::remote_addr]
