iRule to Extract and Repsond back with client IP
All,
I've got the following iRule setup that's being used as a health check for some of our clients.  Right now the text we reply back with is a basic static value "TestOk".  I'm wondering if its possible to something more dynamic where we extract the IP address of the client and respond back with it as the value, but so far I haven't had any luck.  I've looked around here for a similar topic, but haven't found anything yet.
when CLIENT_ACCEPTED { if {[active_members client-443-pool-01] < 1}{ reject } }
Look for a URI If found send back an HTTP 200 if { [HTTP::uri] equals “/about/health/status” } { Send a 200 response with data HTTP::respond 200 “X-Responce” “TestOk” } else { drop } }
Give this a try:
    if { [HTTP::uri] equals "/about/health/status" } {
        HTTP::respond 200 "X-Responce" "TestOk for client [getfield [IP::client_addr] {%} 1]"
    else {
        drop
Give this a try:
    else {
        drop
I assume you understand that “X-Response” will be returned to the client as an HTTP header. If you want the data to be present in the HTTP payload you’d use the “Content” tag:
        HTTP::respond 200 Content "TestOK"
As far as the data that you send back, that can come from any values presented in the client’s request and potentially a wealth of server side information. For example, to send the client’s IP back:
        HTTP::respond 200 X-Response "TestOK: [IP::client_addr]"
Thanks for the quick response Brad, I’ll give that a try. I just got it working with the following as well. when CLIENT_ACCEPTED { if {[active_members client-443-pool-01] < 1}{ reject } } when HTTP_REQUEST { Look for a URI If found send back an HTTP 200 if { [HTTP::uri] equals “/about/health/status” } { Send a 200 response with data HTTP::respond 200 “X-PublicIP” “[IP::client_addr]” “X-Responce” “TestOk” } else { drop } }
