Irule to exempt redirection for connections from specific IP/range and redirect all other traffic to https
I am using below irule, my requirement is when request comes from specific set of IP or range of IP redirection should not happen and all other connections/requests should get https redirection. Kindly assist as below used irule statistics shows hits but all are failing.
when HTTP_REQUEST {log local0. “Client: [IP::client_addr]” if { [class match [IP::client_addr] contains cdm_test_range] } {HTTP::redirect http://[HTTP::host][HTTP::uri] pool cdms-stg-pool-tcp80 } else {HTTP::redirect https://[HTTP::host][HTTP::uri] } }
Hi Habib,
I assume you have two virtual servers, one for port 80 and the other for port 443. And that each has a default pool configured. If so, then the following iRule should work:
   log local0. "Client: [IP::client_addr]"
   if { ![class match [IP::client_addr] contains cdm_test_range] } {
Hope that helps.
Ciao Stefan :slightly_smiling_face:
Hi Habib,
can you try it with this line?
if { ![class match [IP::client_addr] equals cdm_test_range] } {
I assume your DGL “cdm_test_range” is from type address.
Didn’t you see any iRule/TCL error message in your logs, which could be helpful?
Another question: you mentioned that your poolmember is listening on port 443 only. Do you have a serverSSL profile then activated on your HTTP-VIP? Is access via both virtual servers (80 & 443) working in general without any iRule?
