iRule to disable APM not working as expected
   set header [HTTP::header "User-Agent"]
    log local0. "Before Match --- Header is: $header"
    if {[string tolower [HTTP::header "User-Agent"]] contains "mac os x"  && [string tolower [HTTP::uri]] equals "/ews/exchange.asmx"} {
            ACCESS::disable
            log local0. "one time"
            log local0. "URI: [HTTP::uri]"
            pool /Common/exchange.app/exchange_oa_pool6
Cannot save or edit the post so: APM is still causing grief for Mac clients. I am trying to disable the policy for Mac User-Agent headers. This is killing the session but resulting in a apm loop (it just creates an immediate subsequent session ID). Any ideas?
If your request has any of the apm cookies, you may need to remove them from that request. I’ve had weird issues like that.
so, perhaps your iRule could do something like this:
        log local0. "  Disable access for [HTTP::uri]"
        ACCESS::disable
        HTTP::cookie remove "MRHSession"
        HTTP::cookie remove "LastMRH_Session"
        log local0. "  [HTTP::uri]"
May want to try with
when CLIENT_ACCEPTED {
    ACCESS::restrict_irule_events disable
Don’t I need to have an iRule event in the access policy event for this then?
Not required.
Not required.
which version of TMOS? I experienced having to build in a timer in a similar situation before 11.4.
are you sure there are any requests to other URI also?
set u [HTTP::header "User-Agent"]
set uru [HTTP::uri]
log local0.notice "user agent: $u and uri: $uru"
    if {[string tolower [HTTP::header "User-Agent"]] contains "mac os x" } {
            ACCESS::disable
Doesnt work and ltm logging shows only:
    Apr  7 10:29:29 loadbalancerhostname.something notice tmm2[18680]: Rule /Common/OS-X_Kill_Preauth : user agent: Mac OS X/10.10.2 (14C1514); ExchangeWebServices/5.0 (213); Mail/8.2 (2070.6) and uri: /EWS/exchange.asmx
Apr  7 10:29:30 loadbalancerhostname.something notice tmm2[18680]: Rule /Common/OS-X_Kill_Preauth : user agent: Mac OS X/10.10.2 (14C1514); ExchangeWebServices/5.0 (213); Mail/8.2 (2070.6) and uri: /EWS/exchange.asmx
It should hit pool configured for the virtual server without creating access session. What do you expect in the logs?
What I expect in the logs is what I see and posted for everyone’s clarity. It hits the pool just fine but my problem is the access session gets created!
Tested the following iRule with curl
curl -k -L https://10.2.60.70
  set uru [HTTP::uri]
  if {[string tolower [HTTP::header "User-Agent"]] contains "curl" } {
    ACCESS::disable
when ACCESS_SESSION_STARTED {
   log local0.notice "Access session started"
Apr 8 22:03:50 bigip6 notice tmm1[15943]: Rule /Common/accessDisable : user agent: curl/7.19.7 (x86_64-redhat-linux-gnu) libcurl/7.19.7 OpenSSL/1.0.1j zlib/1.2.3 libidn/0.6.5 and uri: /
The logs doesn’t have the Access session started message. Is there anything else done in your iRule?
hey thanks for taking the time to reproduce though my behaviour is different. I’ve added when ACCESS_SESSION_STARTED and I do see the session. Even when simply trying the [HTTP::host][HTTP::uri] directly from a web browser.
*Apr 8 16:08:17 lhr4-exlb-01 notice tmm2[18680]: Rule /Common/OS-X_Kill_Preauth : hey I found a Mac so Disabling Acces policy…CLIENT IP 10.164.4.23 user agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.10; rv:35.0) Gecko/20100101 Firefox/35.0 and uri: /ews/exchange.asmx
Apr 8 16:08:17 lhr4-exlb-01 notice tmm2[18680]: Rule /Common/OS-X_Kill_Preauth : Access session started for 10.164.4.23 and user agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.10; rv:35.0) Gecko/20100101 Firefox/35.0*
irule: when HTTP_REQUEST { set u [HTTP::header “User-Agent”] set uru [HTTP::uri]
            ACCESS::disable
                          log local0.notice "hey I found a Mac so Disabling Acces policy...CLIENT IP [IP::client_addr] user agent: $u and uri: $uru"
   log local0.notice "Access session started for [IP::client_addr] and user agent: [HTTP::header "User-Agent"]"
still hard to get
