I want to implement irule which can delete persistence table for particular pool member when it will be marked down by F5.
Hi Kalpesh, BIG-IP shouldn’t forward a new connection to a pool member that’s marked down, regardless of whether or not it matches a persistence entry. I don’t think you can manipulate the persistence table through iRules.
