Hello,
Here i am searching for a solution to connect to a public domain (www.ventanillaunica.gob.mx)) via web proxy
User/client(https://test.mydomain.com)) => LTM VIP => Proxy pool => internet ==>https://www.ventanillaunica.gob.mx .
User is initiating HTTPS connection to vip and we can add web-proxy server(http/https) with anonymous access to this pool then the request should go to the destination domain.
Can some one help me with this
What is your actual question or problem that you want to sort ? Please elaborate
the destination domain is hosted on amazon elb hence the ip is keep changing we don’t have option to auto populate pool members if we auto populate also firewall change required. to avoid all these i want to redirect traffic via proxy
Cnc)(/S1-green-P:Active)(/Common)(tmos.ltm) list virtual test_webpxy ltm virtual test_webpxy { destination 192.168.0.10:any ip-protocol tcp mask 255.255.255.0 pool test_webpxy profiles { tcp { } } rules { test_webpxy } source 0.0.0.0/0 source-address-translation { type automap } translate-port disabled vs-index 564 } /S1-green-P:Active)(/Common)(tmos.ltm) list pool test_webpxy ltm pool test_webpxy { members { webproxy.mydomain.com:webcache { address 192.168.0.65 session monitor-enabled state up } } monitor tcp_half_open } /S1-green-P:Active)(/Common)(tmos.ltm) list rule test_webpxy ltm rule test_webpxy { when CLIENT_ACCEPTED { set bypass 0 set bufferdata “” TCP::collect 0 0 } when CLIENT_DATA { if { $bypass eq 1 } { TCP::payload replace 0 [string length $bufferdata] “” TCP::release return } set bufferdata [TCP::payload] TCP::collect } when SERVER_CONNECTED { serverside {TCP::respond “CONNECT www.ventanillaunica.gob.mx:443 HTTP/1.0\r\n\r\n”} TCP::collect } when SERVER_DATA { if { $bypass eq 1 } { TCP::release return } if { [TCP::payload] starts_with “HTTP/1.0 200 Connection established\r\n\r\n” } { TCP::payload replace 0 39 “” TCP::respond $bufferdata TCP::release set bypass 1 } else { TCP::close } } }
The below one is my config can someone help me
Is this is a client with a web browser (I.E, Firefox, Chrome Safari, etc) or is this for an Application?
-=Bhattman=-
Hi Mike,
I’ve recycled some existing code of my SNI RDP Proxy project for you. Enjoy…
TCP::collect
when CLIENT_DATA {
set tls_start [TCP::payload]
TCP::payload replace 0 [TCP::payload length] "CONNECT www.ventanillaunica.gob.mx:443 HTTP/1.0\r\n\r\n"
TCP::release
TCP::collect
when SERVER_DATA {
if { [TCP::payload] contains "Connection established" } then {
TCP::payload replace 0 [TCP::payload length] ""
TCP::respond $tls_start
unset -nocomplain tls_start
TCP::release
reject
Cheers, Kai
