iRule to check Certificate subject and add http few header values
Hi experts,
Our requirements : [We have LTM & APM on the same unit]
a) Application needs to be exposed based on cert authentication to vendors.
b) Cert subject value should be validated to match a predefined value before allowing the vendor
c) if vendor uses API calls which do not handle multiple 302 redirects while using LTM+APM, insert HTTP::header insert “clientless-mode” 1 which solves the problem.
iRule that I composed based on various forums:
when ACCESS_POLICY_COMPLETED{
if {[SSL::cert count] > 0}{
    set cert [SSL::cert 0]
    set subject [string tolower [X509::subject $cert]]
    set clientIP [IP::client_addr]
    if { $subject contains “cn=vendor-a.xx.com” }
        HTTP::header insert X-UPN vendor-a.xx.com
elseif { $subject contains “cn=salesforce.xx.com” }{
        HTTP::header insert X-UPN salesforce.xx.comm
        log $clientIP
        log local0. “cert CN not valid”
        reject
Problem:
API calls from salesforce cant handle multiple 302’s from LTM+APM [if i am not wrong, it struggles after three 302s]. Since I use ACCESS_POLICY_COMPLETED, there will be a 302 which cant be avoided.
Questions:
Can I move this logic other than ACCESS_POLICY_COMPLETED?
Is there a better way to handle these requirements?
HTTP commands and probably also SSL commands are not available in ACCESS_POLICY_COMPLETED event.
You may want to stuff values you need in the session table while still in the HTTP_REQUEST event, then you can access them in ACCESS_POLICY_COMPLETED using the [ACCESS::data get ] command.
    ACCESS::session data set session.x509.cert_subject $subject
when ACCESS_POLICY_COMPLETED {
   set cert_subject [    ACCESS::session data get session.x509.cert_subject]
I have not checked lately but this data may already be in the APM session table.
HTH
The certificate info is collected and stored in the session variable tables:
Client certificate authentication
    session.ssl.cert.x509extension  string  X509 extensions
    session.ssl.cert.valid      string  Certificate result: OK or error string
    session.ssl.cert.exist      integer     0 or 1.
        0 - Certificate does not exist
        1 - Certificate exists
    session.ssl.cert.version    string  Certificate version
    session.ssl.cert.subject    string  Certificate subject field
    session.ssl.cert.serial     string  Certificate serial number
    session.ssl.cert.end        string  Validity end date
    session.ssl.cert.start      string  Validity start date
    session.ssl.cert.issuer     string  Certificate issuer
    session.ssl.cert.whole      string  The whole certificate
Thx John for these details. My requirement is to set HTTP::header insert X-UPN salesforce.xx.comm & HTTP::header insert “clientless-mode” 1" values before we even hit APM. Can I use the above iRule within HTTP_REQUEST? This way we can avoid 302 redirection which causes issues with our Salesforce API calls.
If I just use below
HTTP_REQUEST {
Salesforce API calls works fine. If I use them under ACCESS_POLICY_COMPLETED [which will wait for APM to be completed and also cause a 302 [i.e /my.policy], Salesforce API calls fails.
Sure, you can use command in above iRule in the HTTP_REQUEST event.
I am running into the issue with APM module… Have tech open and no luck., Found that they have stop providing support for auth profile in LTM… and F5 preferring to use APM.. I have iRule assigned to vserver for client mode 1 when HTTP_REQUEST { HTTP::header insert “clientless-mode” 1 } With browser it works fine but not with http client. Hope to get some help and instruction around how I can get clientless working with APM or using iRule..
It’s frustrating to hear from Tech that browser base client cert is working through APM that states configuration is right, and iRule for clientless and APM on-demand cert doesn’t work well together,
Clientless Mode and OnDemand Cert Auth do not work together well and it’s hit or miss , but in most cases it doesn’t work.
Our APM operations guide mentions that these two will not normally function together.
In ACE we never had any issue with those clientlesss, not sure why would it be an issue on F5.
Please let me know if there is an irule to do cert authetication for those clientless connection..
Thanks.
