iRule to calculate client bandwidth usage
hi all,
Just wondered if there was a way to calculate user/client bandwidth per VS and then apply a rateclass when a limit is reached?
I think this can be done with an iRule but not sure where to start!
Help appreciated as always.
thanks.
what is different with applying rate class to virtual server without calculation?
maybe i should have posed my question a little different and explain the situation…
I have clients connecting to a VS to download files and once they have downloaded say 500mb of data then i need to shape the traffic down so for instance shape the traffic down for that perticular client so once they hit a download limit of 500mb then the bandwidth they are allowed is down to say 1mbit/s.
Thanks.
just wondering whether you have seen this one. would it be applicable?
Simple traffic shaping by JackofallTrades
http://devcentral.f5.com/wiki/iRules.Simple\_traffic\_shaping.ashx
e.g.
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.65.152:http
ip protocol tcp
rules myrule
[root@ve1023:Active] config b rule myrule list
rule myrule {
when SERVER_CONNECTED {
TCP::collect
when SERVER_DATA {
set srvAge [IP::stats age]
set srvBytes [IP::stats bytes in]
if {$srvAge > 10000 } {
if {$srvBytes > 3000000 } {
rateclass bandHog
TCP::release
log local0. “Bandwidth Hog: [IP::client_addr] server bytes $srvBytes”
return
TCP::release
TCP::collect
[root@ve1023:Active] config b rate class list
rate class bandHog {
rate 1Mbps
ceiling 1Mbps
drop policy tail
type sfq
[root@ve1023:Active] config tail -f /var/log/ltm
Nov 9 05:53:41 local/tmm info tmm[4766]: Rule myrule : Bandwidth Hog: 192.168.206.102 server bytes 137926996
thanks thats a great start for me to go on, will have a re-jig of the rule and see whati come up with :slight_smile:
