Irule to block Requests with specific word
Hello All, I’ve many websites hosted behind F5 Lately im getting alot of spam through the “contact-us” form with a specific words like " viagra " or something like that. Is there any possible way to block POST requests with the word “viagra” ?
Thanks in Advance.
This isn’t tested, but may be a useful starting point for you. You can use HTTP::collect to collect payload data and find what you’re looking for in HTTP_REQUEST_DATA.
Putting restricted words in a datagroup means you don’t have to change the iRule everytime you add a new word.
DATAGROUP
ltm data-group internal restricted_dg {
    records {
        restricted_word {}
    type string
IRULE
    if {[HTTP::method] eq "POST"} {
        HTTP::collect 100
when HTTP_REQUEST_DATA {
    set payload [HTTP::payload]
    if {[class match $payload contains "restricted_dg"]} {
        log local0. "Rejecting restricted content"
        reject
HTTP::payload DevCentral - An F5 Technical Community
HTTP::collect DevCentral - An F5 Technical Community
Updated post with fully working iRule using datagroup
Datagroup:
    records {
        restricted {}
    type string
Testing
curl --data "param1=restricted&param2=notrestricted" http://10.1.1.1
Jan 24 14:13:20 BIGIP info tmm1[19064]: Rule /Common/ls-http-collect : Rejecting restricted content
iRule:
    if {[HTTP::header exists "Content-Length"] && [HTTP::header "Content-Length"] <= 1048576} {
        set content_length [HTTP::header value "Content-Length"]
        set content_length 1048576
    if { $content_length > 0} {
            HTTP::collect [HTTP::header "Content-Length"]
        log local0. "ERROR! Content Length = $content_length"
        reject
Try this code to prevent issue. the problem may be the variable payload contains space and the code fails as the following string in the payload is read as a new argument. this solution will bypass the issue but may let some SPAM get in.
Collect a request payload
  if {[HTTP::method] eq "POST"}{
     Trigger collection for up to 1MB of data
    if {[HTTP::header "Content-Length"] ne "" && [HTTP::header "Content-Length"] <= 1048576}{
      set content_length [HTTP::header "Content-Length"]
     Check if $content_length is not set to 0
      HTTP::collect $content_length
    catch {
            reject
    HTTP::release
