iRule to block IP for period of time.
I need to create iRule to block client IP if it met below condition :
  • if client try to do attack ex: sql injection 3 times
then i want to block this IP for 1 hour and after 1 hour the IP should be unblocked .
is it possible to do this?
Hello Blue.
You can react to a ASM violation using an iRule. Some examples:
After that you could include that IP into a table variable with one hour of timeout. This table would be checked everytime you receive a request. I did a similar iRule here:
Regards,
Dario.
