iRule to block http content
Hello all,
I am looking for a simple iRule to inspect HTTP content that is sent back via POST from a particular user and drop if the HTTP content contains
id=sa_sabre&event=sa_exchangeSrvr_state
or
id=sa_sabre&event=sa_sip_state.
Thank you
try this irule:
    if {([URI::query [HTTP::uri] id] equals "sa_sabre") && (([URI::query [HTTP::uri] event] equals "sa_exchangeSrvr_state") || ([URI::query [HTTP::uri] event] equals "sa_sip_state"))}  {
        drop
This irule do the same for POST method:
   if { [HTTP::method] eq "POST" } {
       Trigger the collection for up to 1MB of data
      if { [HTTP::header Content-Length] ne "" and [HTTP::header value Content-Length] <= 1048576 } {
         set content_length [HTTP::header value Content-Length]
         set content_length 1048576
       Check if $content-length is not set to 0
      if { $content_length > 0 } {
         HTTP::collect $content_length
when HTTP_REQUEST_DATA {
    Do stuff with the payload
   set payload "?[HTTP::payload]"
   if {([URI::query $payload id] equals "sa_sabre") && (([URI::query $payload event] equals "sa_exchangeSrvr_state") || ([URI::query $payload event] equals "sa_sip_state"))}  {
        drop
There is some encoding errors in the above irule, try this one instead, it’s the same with some fixed encoding chars :
      if { [HTTP::header Content-Length] ne "" and [HTTP::header value Content-Length] >= 1048576 } {
        drop
        drop
Still getting errors when saving the iRule: 01070151:3: Rule [/Common/Block_Polycom] error: /Common/Block_Polycom:18: error: [parse error: PARSE syntax 622 {syntax error in expression “([URI::query $payload id] equals “sa_sabre”) && (([U…”: variable references require preceding $}][{([URI::query $payload id] equals “sa_sabre”) && (([URI::query $payload event] equals “sa_exchangeSrvr_state”) || ([URI::query $payload event] equals “sa_sip_state”))}] LTM is using: 11.6.06.0.442
OK removed && and replaced with “and” and the iRule saved.
Thank you for the rule. Question, when applying irule to our resources, we get the following error: 01070394:3: HTTP_REQUEST event in rule (/Common/Block_Polycom) requires an associated HTTP or FASTHTTP profile on the virtual server (/Common/vs-TMS-HTTPS). The Virtual server config is: tmsh create ltm virtual vs-TMS-HTTPS {description “TMS Redundancy Virtual Server” destination 10.0.200.40:443 ip-protocol tcp mask 255.255.255.255 pool pl-TMS-HTTPS profiles add {fastL4} source 0.0.0.0/0 source-address-translation {type automap} translate-address enabled translate-port enabled vlans add {internal} vlans-enabled} How can we get this iRule applied to our virtual server?
Unfortunately, This irule require an http or fasthttp profile. not fastL4.
Can the iRule be modified to use the FastL4?
Hi, unfortunately you need to have a “standard” vs and http profile attached to be able to inspect http
