iRule to block anything containing /user thats not coming for internal network specified in datagroup. I have the following logic but its for the entire url..how can I make it just /user on the VIP?
rule URL-user_rule { when HTTP_REQUEST { switch -glob [string tolower [HTTP::host]] { domain.name.com { if { not ([class match [IP::client_addr] equals sntru_net]) } { discard } } default { pool [LB::server pool] } } } }
I assume you still want to match the Host header and you want to match anything starting with “/user”:
if { [string tolower [HTTP::host]] eq "domain.name.com" and not ([class match [IP::client_addr] equals sntru_net]) } {
switch -glob [HTTP::path] {
"/user" -
"/user/*" {
discard
You don’t need the
default
branch because selection of the assigned pool is what will happen by default already.
"/user" -
"/user/*" {
discard
You don’t need the
default
