Hi
I have an issue with an iRule working in a Virtual LAB environment but when applied to the live environment it behaves differently. The difference between the Virtual LAB and the live is the IP addressing.
The iRule that I have composed is to block access to folders on the backend IIS servers based on the contents of the URI. There are three folders on the servers that are not to be accessed from outside of the organisation. To add complexity to the issue there is a connection to a third party that has the client connections NAT’d behind an IP address that forms part of our internal network.
So the iRule must…
1. block access to the folders from IP address 10.x.x.x/32 (the third Party NAT’d address)
2. allow access to the folders from all other internal IP addresses.
3. block access to the folders from all other IP addresses.
I have set this up in a Virtual LAB using the following IP addressing.
Internal Networks: 10.10.200.0/24; 10.10.201.0/24
Host acting as 3rd Party NAT: 10.10.200.6
External Network: 80.80.80.0/24
All connectivity is fine and without the iRule access to the folders is granted. When I apply the iRule access is blocked to the 3rd party NAT host and the External host on 80.80.80.0/24. Other hosts on the 10.10.200.0/24 and 10.10.201.0/24 can access the web site within the folders as defined in the URI.
So all is well. Until this is applied to the live environment when the iRule does not allow anything through. It blocks all attempts to access even when the folders are not within the URI.
The differences between the Virtual lab and the live environment are…
Lab is VM; live is physical box
lab is HTTP; live is HTTPS
IP addressing is different in the lab but logically the same.
Lab backend servers are Ubuntu running apache2. Live servers are Windows running IIS.
Below is the iRule from the lab. (the only thing that changes in this rule when put into the live environmetn is the IP address of the NAT host)
if {([HTTP::uri] contains "_vti_bin" || [HTTP::uri] contains "_layouts" || [HTTP::uri] contains "_windows") and [IP::addr [IP::remote_addr] equals 10.10.200.6/32 ] } {
log local0. "dropped connection my ip address: [IP::remote_addr]"
reject
if {([HTTP::uri] contains "_vti_bin" || [HTTP::uri] contains "_layouts" || [HTTP::uri] contains "_windows" ) and not [IP::addr [IP::remote_addr] equals 10.0.0.0/8 ] } {
reject
any help will be greatly appreciated.
