block an address if it sends more than 3 “GET /” requests per second
There a codeshare page that has an example of rate limiting. You could start with that and modify as needed.
There’s also another question and a more complex request limiter codeshare page too.
please just enter search term “request rate limit” to find a couple of related articels and tested code in code share section.
Three requests per second limit may lead to block all clients.
The browser will probably send at least a request for the default page and the favicon.
Your page was probably build with more than one object so it takes multiple requests to get all objects of the page.
Thanks, Stephan
