iRule to allow only TCP port 444, 8000, and 9001
I am configuring a VIP using port 0 to allow all traffic and an iRule to drop everything but TCP ports 444, 8000, and 9001 but my iRule syntax is not being accepted. Here is what I was attempting to configure;
when CLIENT_ACCEPTED { if { not ( [TCP::client_port] != 444 or [TCP::client_port] != 8000 or [TCP::client_port] != 9001 } { drop } }
Any help correcting this iRule would be greatly appreciated.
couple of things, you are missing a closed parenthesis, I’m guessing you want to use the dest ports on the client connection not the source ports so you could use TCP::local_port, also no need to negate the equals if you already have a NOT at the end. This should work for you.
    if { not ([TCP::local_port] eq 444 or [TCP::local_port] eq 8000 or [TCP::local_port] eq 9001) } {
      drop
