iRule to add Cache-Control:Public for files download issue over ssl
For the problem of pdf/excel/doc file download over HTTPS and IE issue
following article says create a irule to add Cache-Control:Public
http://support.f5.com/kb/en-us/solu…r=22662958
If I create the above rule this would be applicable
for ALL HTTP responses (be it for dynamic aspx / php/ jsp / static ) .
That should be problematic for dynamic content . right ?
SHould that rule be only created for static file types(pdf,exl,doc) in question ? Please help
A data group might be better for performance but try something like this;
when HTTP_RESPONSE {
   if { [HTTP::header value Content-Type] contains "application/pdf" } {
    HTTP::header replace Pragma public
    HTTP::header replace Cache-Control public }
   elseif { [HTTP::header value Content-Type] contains "application/vnd.ms-excel" } {
   elseif { [HTTP::header value Content-Type] contains "application/msword" } {
   else { return }
Sure, because I have stock ticker website (ASPX) , now if F5 is adding cache-control:public to ALL the requests (dynamic + static).
my users see stale data on my aspx page (which is dynamic page)
Is there a way to request for modiification of that article with the correct iRule code
So that people like my does not suffer
Understood. You could use the comment area at the bottom of that article to request it is updated but of course, every users needs are different so typically the minimum code needed to resolve an issue is listed and you are expected to build/code your requirements around F5’s ‘starting point’.
