irule to a Persistent pool
How do I setup a Persistent connection(use Persistent pool) in an iRule?
e.g.
when CLIENT_ACCEPTED {
if { [TCP::local_port] equals 23}{
pool HGC_Persistent_GW
I need all port23 services to go to this pool Persistently.
Hi Michael,
You would create a persistent profile. I not exactly which version of the LTM you are using, but Click here to see some instructions.
I hope this helps
Bhattman
