You can use the binary scan command to check the SSL header. I’m confused though - how can you remove the extension from the SSL header? that is quite literally a MITM attack which is what SSL is designed to prevent.
There are SSL commands which you can use to extract the extensions ( SSL::extensions ) but of course for that you need to operate at the SSL level. At the TCP level you would have to binary scan the client hello, work out exactly where that extension is and extract only that part of the data. That is quite tricky with variable length headers ie the extension you want may be the first or the third and the SSL header includes a number of variable-length fields. Not easy to do, especially in TCL. I’m sure it’s possible but it it more than i could write here.
