So recently I created a https front-end to a http application so I could put a SSO apm policy on the front-end for external entities to access the site. I then realized that the application developer’s hard coded absolute links into the sites code pointing to http. So I tried putting a generic stream profile on the Virtual Server and using the irule off devcentral to rewrite the link’s on the responses back to the user. However when I try to do this I receive this tcl error in the logs and it breaks my virtual server.
TCL error: /Common/http_rewrite_https - Operation not supported (line 1) invoked from within “STREAM::expression {@http://test.com@https://test.com@}”
Here is the irule that I’m using off of Devcentral.
That SOL made me chuckle a little. It hadn’t occurred to me to use a layered VIP to fix this, and I’m not 100% convinced that it couldn’t be solved without it. I do know that the problem indicated in the SOL is still there in 11.5 and that it only manifests (oddly) under certain visual policy configurations. So in any case, a layered VIP should indeed solve the issue. Put an LTM VIP on the outside, with your STREAM processing iRule, and send the traffic to an internal APM VIP. You could alternately put the APM VIP on the outside and the LTM VIP with STREAM iRule on the inside.
I tried using the solution sol12558 (version 11.5.1) but when using Network Access it will fail, when using a LTM frontend forwarding to a APM backend virtual. What seems to work for me is using the opposite sandwich with apm as frontend and ltm as backend.
I’ve tried to find the course but all I could tell was that the request “GET /isession?sess=xxxxxxxxxxxxx&ipv4=yes&ipv6=yes HTTP/1.0” is truncated, or only half answered, when using a ltm frontend.
Hello, I know this has been around a while but the single VS solution I use is to place a catch around the stream disable and only enable the stream when the policy is in the allow state using a flag:
when CLIENT_ACCEPTED { set disableStream 1 }
when HTTP_REQUEST { catch { STREAM::disable } }
when ACCESS_ACL_ALLOWED { set disableStream 0 }
when HTTP_RESPONSE { if { $disableStream } { return }
rest of STREAM code
I’m fairly sure you have to disable stream in HTTP_RESPONSE if you are going to replace/update the string.
I believe that STREAM replacement is enabled in both directions (inbound on REQUEST and outbound on RESPONSE) but they are treated independently. So you have to disable on both.
