i built below irule to block all other countries accept Saudi arabia.
but i am getting errors on F5 when want to save it. below are the errors.
when HTTP_REQUEST
# Define the URI to be protected
set protected_uri “/uri”
# Define the allowed Country
Set allowed_country “SA”
# Get the country code from the client’s IP address
set client_ip [IP::client_addr]
set client_country [whereis $client_ip country]
# check if the URI matches and if the country is allowed
if {
([HTTPS::uri] equals $protected_uri) && ($client_country for the URI [ HTTP::uri] from IP $client_ip"
#send a 403 Forbidden response
HTTP::respond 403 content “Access denied”
01070151:3: Rule [/Common/Geofencing] error: /Common/Geofencing:8: error: [undefined procedure: Set][Set allowed_country “SA” ]
/Common/Geofencing:17: error: [parse error: PARSE syntax 392 {syntax error in expression "
([HTTPS::uri] equals $protected_uri) && ($client_country …": looking for close parenthesis}][{
HTTP::respond 403 contecnt “Access denied”
/Common/Geofencing:24: error: [missing a script after “if”][]
