iRule Syntax
Can someone show me the equivalent syntax for the following 4.x iRule for version 9.x?
if (http_header(“User-Agent”) contains “test”) {
use pool bot
else {
if (client_addr == 1.1.1.0 netmask 255.255.255.0) {
use pool test
else {
if (client_addr == 2.2.2.2) {
use pool test
else {
if (client_addr == 3.3.3.3) {
use pool test
else {
if (client_addr == 4.4.4.4) {
discard
else {
if (http_header(“User-Agent”) contains “test2”) {
use pool test
else {
if (http_header(“User-Agent”) contains “test3”) {
use pool test
else {
if (http_header(“User-Agent”) contains “test.test.com”) {
use pool test
else {
use pool otherpool
A direct mapping would be something like this (using elseif’s instead of nested if’s):
  if { [HTTP::header "User-Agent"] contains "test" } {
    pool bot
  } elseif { [IP::addr "[IP::client_addr]/24" equals "1.1.1.0/24"] } {
    pool test
  } elseif { [IP::addr "[IP::client_addr]" equals "2.2.2.2"] } {
    pool test
  } elseif { [IP::addr "[IP::client_addr]" equals "3.3.3.3"] } {
    pool test
  } elseif { [IP::addr "[IP::client_addr]" equals "4.4.4.4"] } {
    discard
  } elseif { [HTTP::header "User-Agent"] contains "test2" } {
    pool test
  } elseif { [HTTP::header "User-Agent"] contains "test3" } {
    pool test
  } elseif { [HTTP::header "User-Agent"] contains "test.test.com" } {
    pool test
    pool otherpool
You could probably optimize this a bit by using data groups in combination with the matchclass command to combine a couple of those elseif’s into a single. Right now the rule isn’t too long, but if there were more User-Agent conditions tested all resulting in the same pool command then a matchclass approach might be more manageable.
-Joe
Thanks Joe…
so this would be the correct syntax using a data group named fc_subnet?
elseif { [matchclass [IP::client_addr] equals [$::fc_subnet]] }
{pool www_pool}
in this example fc_subnet = a /27 network. Do I need the /27 in the [IP:client_addr] argument as well?
Thanks again
This looks good but you might want to check out this thread for some version specific issues with matchclass and netmasks.
Click here
-Joe
