Hello, I am trying to write a simple irule but I am getting error. I have no clue why. Can anybody have a look at it and explain me what I am doing wrong? Thank you.
when HTTP_REQUEST { if { [IP::addr [IP::client_addr] equals 212.222.10.211%1] and [active_members V1_P_NSIVMQ1] == 1 } { pool V1_P_NSIVMQ1 } else if { [IP::addr [IP::client_addr] equals 212.122.20.212%1] and [active_members V1_P_NSIVMQ2] == 1 } { pool V1_P_NSIVMQ2 } else if { [IP::addr [IP::client_addr] equals 212.243.220.213%1] and [active_members V1_P_NSIVMQ3] == 1 } { pool V1_P_NSIVMQ3 } else { pool V1_P_NSIVMQ1-3 } }
Hi Maciej,
Try using ‘elseif’ instead of ‘else if’.
Best regards,
Niels
Hello,
It’s even better to use the switch/case instead of if elseif else.
Thank you very much Niels and Yann
this irule may help you to manage pool assignment in a array:
when RULE_INIT {
array set static::V1_P_NSIVM {
"212.222.10.211%1" V1_P_NSIVMQ1
"212.222.10.212%1" V1_P_NSIVMQ2
"212.222.10.213%1" V1_P_NSIVMQ3
if {[info exists static::V1_P_NSIVM([IP::client_addr])] && ([active_members $static::V1_P_NSIVM([IP::client_addr])] == 1 )} {
pool $static::V1_P_NSIVM([IP::client_addr])
else pool V1_P_NSIVMQ1-3
Or if you create a pool with only one member, you can assign pool member in the irule instead (with this irule, the pool V1_P_NSIVMQ1-3 may be assigned to the VS):
when RULE_INIT {
"212.222.10.211%1" {1.1.1.1 80}
"212.222.10.212%1" {1.1.1.2 80}
"212.222.10.213%1" {1.1.1.3 80}
set default_pool [LB::server pool]
if {[info exists static::V1_P_NSIVM([IP::client_addr])]} {
set member(ip) [lindex $static::V1_P_NSIVM([IP::client_addr]) 0]
set member(port) [lindex $static::V1_P_NSIVM([IP::client_addr]) 1]
if { [LB::status pool $default_pool member $member(ip) $member(port)] eq "up" }} {
unset member
unset default_pool
