iRule: 'Switch -glob' does not work with HTTP::payload, it works using 'if-elseif' logic.
Anyway how to use 'switch -glob' to search HTTP::payload?
It works with 'if-elseif' logic.
Also, is the HTTP::release advisable to add?
  if { [HTTP::method] equals "POST" }{
    HTTP::collect [HTTP::header Content-Length]
when HTTP_REQUEST_DATA {
  switch -glob [HTTP::payload] {
apple {
                    pool apple_pool
orange {
                    pool orange_pool
It will work, but I’m guessing you need to allow for some padding:
        "*apple*" {
            pool apple_pool
        "*orange*" {
            pool orange_pool
You shouldn’t need to issue the HTTP::release command because you’re explicitly defining the amount of payload to collect using the Content-Length header.
