iRule SSL Client
We have an SSL only VIP and have a need to access it from an iRule associated with another VIP. Normally we just use the virtual or node command to connect to another VIP on the LTM, but that doesn’t work because this particular VIP requires SSL.
Is it possible within an iRule to be an SSL Client and connect to an SSL Server?
Thanks,
-Dan
You should be able to add a serverssl profile to your vip, and then add some code that looks like:
when SERVER_CONNECTED {
   if { $need_ssl_only_vip } {
     SSL::enable
     virtual ssl_only_vip
     SSL::disable
I haven’t tried this, but it should work.
Hoolio has a great example of this in the codeshare - Click here
Colin
Thanks, the SERVER_CONNECTED code looks promising I will test that out and report back. The codeshare one to me looks like it is how to handle this creatively on the receiving end…
-Dan
