iRule - Source Port persistence for a specific subnet else only source addr persistence
Hi, I need an iRule help. I want to apply source port persistence on a specific subnet (10.1.1.0/24) and for all the other traffic coming to the same VIP, I just want to Source address persistence. I created a datagroup which contain a subnet for port persistence. The thing i am not sure is how to write the else part in iRule for Source address persistence for all the other traffic other then the specific subnet.
when CLIENT_ACCEPTED {
   if {[class match [IP::client_addr] equals "datagroup_dg"]}{
     set client_ip_port "[IP::client_addr]:[TCP::client_port]"
     persist uie $client_ip_port
   else {
I am assuming that you are using the iRule in an UIE persistence profile that is attached to the VS.
In the iRule example that I have provided, persistence is based on “Client IP & Client Port” if the client IP matches the “datagroup_dg” and for client IP not matching the datagroup, persistence is based on just the “Client IP”
In the else statement use
persist uie [IP::client_addr]
   if {[class match [IP::client_addr] equals "datagroup_dg"]} {
   else {
When you add information for the “value” field (seen in GUI) within the data group, you will be able to see the “data” keyword in the CLI within the datagroup like this:
ltm data-group internal CLASS-IP-DATA {
    records {
        10.10.10.0/24 {
            data abcd
    type ip
Datagroup format:
    records {
        1.1.1.1/32 { }
    type ip
Thanks Odaah, I am not using persistence profile for this VIP. Do I have to ? and so the the complete iRule would looks like this. Please verify !!!
   else {
and also I wanted to know the datagroup format can you please verify the following:
ltm data-group internal addr_testclass {
    records {
        10.1.1.0/24 { }
            data "what is this part for ?"
    type ip
I recommend using the UIE persistence profile. If not, we would have to add “persist add uie [IP::client_addr]” or similar such function in order to add the persistence record to the F5. Using the UIE persistence profile helps us to keep the iRule simple. Also, my 1st reply has been edited to answer the data group question. Let me know if everything has been addressed.
Thanks Odaah, Sorry new to this datagroup formating. I saved the datagroup in a text file and import it from system>File management>data group file list > import but getting following error 0107169a:3: The data group external file (/config/filestore/.stage_d/179660_d/Common_d/data_group_d/:Common:ss_dg_57708_1) has an invalid format, line: 1.
in value filed (GUI) there is already ":="
