iRule Script Request
please I need iRule match the below procedure.
1- Matching by Header " REFERER" section a- Match header " REFERER" contains vlaue MUSEPROXY=1103, then forward traffic persist to sr1 2- By URL pattern a- if URL pattern contains MUSEPROXY=1103, then forward traffic persist to sr1
3- By URL second value
a- if URL pattern contain .1103. then forward traffic persist to sr1
4-if nothing of policies match apply default load balancing " least connections "
The irule below may fit your request :
        switch -glob "[HTTP::header "Referer"]|[HTTP::uri]" {
            "*MUSEPROXY=1103*|*" -
            "*|*MUSEPROXY=1103*" -
            "*|*.1103.*" {
                node srv1
            default {
                 pool defined with least connection lb method
                pool pool1
