Hello,
I need to apply two iRules to a virtual server. One that routes traffic to a certain pool of servers based on the release version in url, 8.32.4. Say https://test.abc.com/dr=dfgv8.32.4 the version stay the same in the string but the letters around will change. Maybe a contains?
A second that routes based on cookie. If we don’t find this release version in the url the second irule will kick in and search for cookie if it finds the cookie it will route to a certain pool of servers.
if none of the irules kick in traffic just goes to the pool of servers attached to the VS.
does anyone know how these might look?
thank you for the help
if { [HTTP::uri] contains "8.32.4" } {
pool pool_A
} elseif { [HTTP::cookie exists "cookieName"] } {
pool pool_B
If the version number is at end of the uri, you can use “ends_with” operator.
if { [HTTP::uri] ends_with "8.32.4" } {
pool pool_A
pool pool_B
Great, thank you for the help! I’ll plan on testing over the next couple of days and let you know.
ok, so i ran into an issue with the cookie. The cookie for example will always be “cookieName” but I need to route according to the version that’s inside the cookie. Is there an irule that will do that?
Can you try this iRule?
set cookieValue [HTTP::cookie value "cookieName"]
# log local0. "CookieValue: $cookieValue"
if { $cookieValue contains "8.32.4" } { pool pool_A }
elseif { $cookieValue contains "8.32.5" } { pool pool_B }
else { pool pool_Z }
else {
pool pool_default
great, I will try this in the lab. Thank you for the help!
hello,
this is working!, thank you. Is it possible to add routing bases on Referer as well?
