Hello,
Is there a way to use an iRule to route traffic from “test.abc.com” as well as inspect the body of the message for say “productcode” then change the host from “test.abc.com” to “hello.abc.com” and then route the traffic to a certain pool of servers? Basically I need to say if you come from “test.abc.com” and contain “postcode” in the body I’m going to change the host to hello.abc.com and send you to this pool of servers.
Any help would be greatly appreciated, stuck on this one.
Thank you,
