hi Team,
Request your help for review the rule and advice.
If user access https://abc.com It should connect on back end node at https://node1.com:6443/cfcc/bclient/index.jsp/ If user access https://abc.com/cc it should connect back end node at
what i did is,created two pools, pool_6443 and pool_7443 and implemneted follwoing rule.
switch -glob [HTTP::uri] {
"/cc" {
set HTTP::uri "/cfcc/control?view=view/admin/start.jsp"
pool pool__7443
default {
pool pool_6443
somehow,this is not working.
Try using a Rewrite profile, which has similar behavior to Apache ProxyPass. You can then use the iRule just to do pool selection and pick a rewrite profile - or use an LTM Policy to select both pool and rewrite profile, which will improve performance and provide a more robust interface for configuration.
Amy, im currently using 10.x version,so cant implement with rewrite profile.. any irules can use best approch?
Certainly. There is an iRule that implements ProxyPass functionality: DevCentral - An F5 Technical Community
